The window channel liner on my 61 Sunliner front windows were toast. Actually, there was hardly any left. As a result the windows rattled horribly when driving. I found some channel liner by the foot and replaced it. I used weatherstrip adhesive to glue it and a wood spacer to insert it into the channel. I put the wood thru a wood planner to get the correct thickness. Using a piece of wood was the only way I could get the liner in the channel properly. It actually went really well, hope the windows won't rattle anymore?
Channel liner:
Wrapping channel liner around spacer:
Getting liner into channel:
Trimming excess:
The spacer actually made a good surface to trim the extra liner. On the lower part of the track(the section inside the door, I just wrapped the extra liner around the channel rather than cut it for more holding power.
fantastic info!! Thanks for sharing it. Let us know how it works when you get the windows back in the car.
I use the same method. were did you buy the liner?
best
Purchased the liner at a local car restoration business...called RPM. Not sure about the price... $4.00 a foot, don't know how that compares?
Did you use weatherstrip adhesive and if so, has it been holding up?
