January 12, 2013 6:50 pm  #1
Power Steering
I've got a 1964 Galaxie 500 Convert, 390" engine, C4 trans. It has a power steering assist system. The oil in it is tractor hydraulic fluid and it foams and blows out the reservoir. What fluid should I be using since this stuff obviously foams?!
Thank you for help.
January 12, 2013 6:56 pm  #2
Re: Power Steering
Welcome to the forum!!  If you go to any auto parts house they sell a power steering specific fluid. I like synthetic oils
January 12, 2013 7:17 pm  #3
Re: Power Steering
So it doesn't have to be Ford specific P/S fluid in the old ones? Not Ford ATF?
January 12, 2013 7:19 pm  #4
Re: Power Steering
Nope. ATF is the only fluid specific to old fords
January 13, 2013 6:52 pm  #5
Re: Power Steering
Gee, the ATF doesn't foam! Tractor hyd. oil does! Duh! A little draining and new ATF and Its fine. How odd!
January 13, 2013 7:36 pm  #6
Re: Power Steering
what I ment is ATF fluid requires somthing different for old ford automatic transmission.  Power steering fluid is power steering fluid.  Nothing specific about it.  If you drain out the hydraulic fluid and replace it with powersteering fliud you should be good to go.
