March 13, 2014 8:57 pm  #1
Electromechanical clocks explained
The clock in my 61 Galaxie is not working. I pulled it out and opened it up and tried a few things. With some information from a local clockmaker I found out why my clock will never live again. I want to share my experience with you in the event you are having clock issues. Borg clocks were used by many car manufactures back in the day. The principle action is for an electric coil to wind a spring and the spring winds the clock. That is your electro and mechanical actions. This action repeats itself as long as voltage is available.
Picture of the back of the clock removed
Next picture shows the coil. It is actually called an electromagnetic coil. When voltage passes thru the coil a magnetic field is produced. It is this magnetic field that winds the main clock spring. Read on...
The next picture shows a screwdriver between a set of points. Look closely and you can see a set of electrical points soldered to a set of arms. One of the arms is stationary, the other arm is attached to a black disc and a spring. The coil is responsible for turning the black disc.
So here is how it all works:
When the points come into contact with each other, they close an electrical circuit. Voltage is allowed to pass thru the points and charge the coil. When current flows thru the coil, the resulting magnetic field causes the black disc to spin. A few things happen at this point. The disc spins back about one third of a rotation causing the arms to pull away from each other and lengthening the main spring.(Winding up the spring) As the spring wants to return to its natural length, it turns the disc in the opposite direction that it was just pulled by the magnetic field. The rotation of the disc winds the clock, turning the clock gears. This is the mechanical action of the clock. As the disc continues to rotate back to it's starting point, the arm on the disc will eventually come into contact with the stationary arm. Once again the points close and the process starts all over again. Remember once the coil rotates the disc, the points open and voltage to the coil is interrupted. There is no more magnetic field to hold the disc so the spring is allowed to rotate the disc back to its starting point winding the clock gears.
A few things to try if your clock doesn't work:
Dirty points: File the points with an emery board until they are clean. Keep them square.
Bad coil: Use a multimeter, set to Ohms. Place one probe on the 12 volt supply terminal of the clock and the other probe on the point of the stationary arm. There should be resistence. No resistance, coil is toast.
Dirty clock. Dirt causes drag on the mechanism. Clean gears, shafts with a spray type electrical connections cleaner. Gentle air dry. Lubricate with clockmakers oil. Don't know what that is exactly. Was told that machine oil or WD-40 type lubricants can cause drag and slow or stop your clock.
Worn out. That is the issue with my clock. The brass shafts that hold the gears can wear. They wear on the pivot points or at the tables were the shafts are supported. When shafts wear, they wobble causing the gears to bind. The clock mechanism is delicate so it doesn't take much to cause drag, which can slow or stop your clock.
I hope this is helpful and not too confusing. I am in no way an expert, just passing along some information that was sent my way.
March 16, 2014 8:20 pm  #2
Re: Electromechanical clocks explained
Great info, Thank You for posting that.
March 17, 2014 12:01 pm  #3
Very interesting.  Thanks for the information.  One of those things that you always wonder "how's that work"?
March 17, 2014 7:19 pm  #4
I managed to find a couple of vendors on Ebay selling quartz replacement kits for the clocks. They are about $90.00. Sounds like you use the face and hands of the old clock with the quartz movement. I guess this one is gonna be low on my priority list...too many other things to buy!!!
March 18, 2014 7:38 pm  #5
very fastination write up, thanks for sharing!!  Make me want to go out to the garage and tear into the clock I have sitting on the shelf just to get a btter appreciation of how it works.  (I took my clock out and replaced it with a tach)
March 18, 2014 9:44 pm  #6
...leave the tach, way more useful, lol
April 13, 2014 11:25 am  #7
some good tips for dignosing the clock in the 65 im buying. thanks
Alice
AliceP.com
GamerGirlAlice.com
ChrisRayMemorial.com
May 7, 2014 8:59 pm  #8
Very informative.  The clock in my 61 is not working at this point, but I need to see if it's still connected to power or if the wire was robbed to power something else....like an 8-track player someone else installed lol.
Speaking of Tachs, anyone have thoughts regarding addind a hood tach?
Dave
61 Galaxie Sunliner 390 4 Speed; 67 Fairlane 500 XL 289/C4; 68 Ford F100 6 cyl/3 Speed; 68 LeMans Convertible 350 4 Speed; 70 Lemans Coupe 350/350; 72 Ford Bronco
