August 14, 2019 5:05 am  #41
Re: cruise o matic to C6 conversion info...
C4 (introduced 1964) was  not installed with FE engines.
FE's could have, depending on the year,  FX & MX Cruise-O-Matic, C6.
Bill / Retired Ford Parts Manager / 1928/89 Ford Passenger Car & 1928/2001 Ford Truck ~ Part Number Research & VIN Decoding
August 15, 2019 5:51 am  #42
The shift linkage from the column to the C6 is back in it's stock Galaxie configuration except a short rod was added at the transmission end to make it reach. The short section is  welded to the Galaxie linkage and at the other end has a 90 degree bend with about an inch to go thru the hole in the shift arm on the C6.
