So, at some point between January 72 and April 72, Ford switched from a choke warm-up arrangement of heater hose/intake heat tube to an electric choke on the Motororcraft 4300 D2AF-AB carburetor. Can anyone tell me where they sourced the power feed from? Thanks in advance!!
Most of the ones I've seen come off the stator terminal at the alternator. Just put on an electric choke cap on my 79 Ranchero and used the stator terminal for power. Work fine.
Thanks, lowrider. Found the terminal and it worked fine! I even found a correct pigtail !!
