May 9, 2016 1:59 pm  #1
63 Country Squire Tailgate Weather Stripping and inop Dash Lights
Hello, I just purchased a 1963 Country Squire Wagon. I'm looking for information/part numbers etc. for the electric window seals on the tailgate. Also the Dash Lights don't work, any thoughts would be appreciated. Thanks
Bill Borthwick
Costa Mesa, Ca.
May 9, 2016 9:20 pm  #2
Re: 63 Country Squire Tailgate Weather Stripping and inop Dash Lights
The fact that none of the lights work, makes me think either a fuse or your headlight/dimmer switch. First thing I would do is check the fuse. If fuse good, I would use a test light and see is you have voltage at one of the dash light bulb sockets. If no voltage I would then suspect the headlight/dimmer switch on the dash.
