August 20, 2014 4:18 am  #1
1964 galaxie vent window
does the window have to be removed in order to remove the vent window frame?
as I am going to replace the vent window rubber seals
thanks
August 25, 2014 11:51 am  #2
Re: 1964 galaxie vent window
I'm thinking you can wiggle the frame out without taking the whole main glass out.  Been quite a few years since I had mine apart(like 1997).  I put new felt slides in mine but the vent rubber was okay.  I also refurbished the crank mechanism as they were sloppy.
