August 30, 2016 9:16 am  #21
Re: new member with a 64 Galaxie 500
Here is a video of the car running. It was started cold, so not warmed up.
https://youtu.be/wOKhoRAjHQw
Does this sound like a high compression motor? It is a circle track engine. I did not get a chance to do a compression check on it.
Thanks.
August 30, 2016 10:23 am  #22
I don't know about compression from listening to it, but it either has a pretty lumpy cam, or the timing is off. Give it a good tune up and check the compression of all cylinders.
August 30, 2016 10:34 am  #23
It definitely has a lumpy cam. I put new plugs in it prior to, and it has an electronic ignition.
