December 31, 2015 9:35 pm  #1
R&P steering column bearing
Daze or anyone doing the R&P swap
Is there a bearing that fits the end of the column but not inside the shift tube?
Since I had a stick column I don't have the shifter tube end
For the 1 3/8 bearing..
Is there one that fits the entire tube end?
1990 Crown Vic Wagon
December 31, 2015 9:55 pm  #2
Re: R&P steering column bearing
Sorry but I can't help there.  I put a Mustang column in my Galaxie which has a bigger diameter.
December 31, 2015 9:59 pm  #3
December 31, 2015 9:59 pm  #4
December 31, 2015 10:17 pm  #5
Daze
The 1 3/8 bearing fits inside the shifter tube of the galaxie
Which mine doesn't have
So I guess I'm looking for the inside diameter of the colum itself type bearing
I thought someone on here did iit that way
I also might go with A 69 Lincoln tilt column
It's the same length as the galaxie column
But has a D shaft already coming out of the column to work with
And I will need to add the support bracket to dash mount
January 1, 2016 10:14 am  #6
Do a search for  "Bearing or bushing". I previously posted a picture and a question about using a bearing vs bushing for the column with the R&P swap. It may provide you with some ideas?
January 1, 2016 11:17 am  #7
69crewcab, what year is the steering column you are working with and what is the ID of the column tube??
January 1, 2016 7:43 pm  #8
Daze 1968 Lincoln
And 2 1/8 is the I.d. Of tube
And has a 1" D shaft
January 1, 2016 7:44 pm  #9
Dan
Thanks I know I saw a posting like that with part #s I think too
I'll look again
January 1, 2016 8:03 pm  #10
I hope the Lincoln column isn't longer than the Galaxie column! If so, you may have issues with u-joint binding when connecting the rack to the column as the u-joint angles will be to sharp.
