February 28, 2013 7:31 pm  #11
Re: Cutting front coil springs...need an answer
Maybe 63gal427 could chime in, he might be able to help you out with regards to your sping type question. He dropped his Galaxie...stance is real nice.
February 28, 2013 8:20 pm  #12
As far as I know my springs were stock, so I cut them.
But there is a reason why I kept the same springs and didn't go for heavy duty ones. Don't laugh......
The reason being that with a 427 and changing gears, it's a great feeling seeing the car raise the front, then drop with the gear change, then raise again through the gears. It might not be the safest way, but I like it!
February 28, 2013 10:09 pm  #13
....ahhhh, big block torque!
