My Fairlane 500 as it appeared around 1986
Moving slowly ahead with the Fairlane resto. I sent out a dual action fuel pump to be rebuilt. I sent one out from a parts motor. I liked this fuel pump because it has a cool glass filter bowl. I think its a Blackstone brand.
This weekend I plan on disassembling the parts motor and harvesting any remaining good parts then scraping the rest. Does anybody need a 61 Cruise-o-matic? I plan on scraping it if no one needs it.
Looks like a fun project. How expensive is the y-block rebuild going to be compared to an FE or a Windsor?
I'm not sure what the cost is of an FE or Windsor rebuild. My machine shop quoted me $3,300 - $4,000 for the Y block rebuild.
This week we removed the 3 speed transmission. Also prepping the motor so we can take it to the machine shop for rebuild. I know it's been bored .030 over before and I believe the crank is .010 & .010. I kept the oil changed regularly so I'm hoping it's rebuildable.
We found this neat mouse nest built from seat padding.
Engine on stand.
Slowly moving forward. I received two new rear quarter panels from Classic Sheet Metal. Also bought a new ring gear for the flywheel as the old one had a few worn teeth and I was planning on having the motor balanced while at the machine shop.
Also I removed the old exhaust manifold studs.
And drilled and removed a broken bolt from a hood I had in storage. Drilling the first hole takes a lot of time and patience.
Hopefully on to some more exciting tasks in the near future.
Looks like you've got your hands full! I passed on two different '62 Galaxies because they had Y-blocks and I wasn't aware of their potential at the time. Both were driveable cars but not great.
Thanks Daze for the new 3-speed shift lever.
Looks right at home. Glad it worked for you and sorry it wasn't as pristine as it could have been
Not sure where you live but I am in eastern part of TN (Knoxville area), the machine shop that I have used for about 15 years is in Pigeon Forge (home of a lot of hot rod & car shows, etc) and the average Y-block re-build runs about $2500 to $3000... that is total cost which includes machine shop cost, parts and labor cost for building.. That assumes an engine is sent to be re-built... not for a new build where everything has to be supplied.
I built 22 T-Bird 312 engines in a row several years ago for a local T-Bird club and the average out-the-door price was just a little over $3500 each but most of the engines had new BT 4V manifolds, new Holley carbs & new MSD ignitions.
I know prices vary depending on locale but that seems to be on the high side. Rick
They may be a little high on the Y block rebuild. There aren't too many machine shops left around this area, much less ones that are familiar with Y blocks. (I'm in Southwest Missouri). This particular shop said they used to rebuild lots of Y blocks but that demand for them has dropped off in recent years. Not sure why?
