Let me look tomorrow and I will see exactly what I have. I know for sure that I do not have the pump, but I should have everything else.
Daze:
That will be great, as I have located the pump and mounting bracket, so all I need is what you showed in your picture on March 2nd. Also, I will try to use my original steering box and may only need the pitman arm. That will save about 28 lbs in shipping. Hope to hear from you soon.
Thomast
The parts in the picture I posted earlier in this thread are exactly the parts I have with the exception of the outer tie rods, those got used in the rack and pinion swap I did.
The control valve has less than 500 miles on it since it was rebuilt. The hydraulic ram on this setup look a little dented and beat up but does not leak and works just fine. As to the steering box I know the manual steering gear box had a different ratio than the power steering box so I am not sure how well yours will work. Let me know what you think.
Daze:
Daze:
What you said is what I need, including the idler arm & bracket and the pitman arm. I hope to use my steering box, as it is different and it does 4 turns, from lock to lock. That I can live with. Shipping should go either, Fedex or Fastenal, if they service your area. What does it it take $ to get that to me?
Tom
Before I figure out what a fair price would be.....No let's make that a good price. Let's first figure out how bad shipping is going to be. Email me your shipping address to day at dazecars dot com and I will get some quotes.
I got both the PM and the email. I will get a quote and get back to you.
sent you an email
sent you a PM
I got your email saying you hadn't heard back from me. I have sent you an email as well as two PM through this web site.
