November 18, 2014 10:27 pm  #1
1966 Galaxie Parts
Hello,
I'm cleaning out the garage.  I have a lot of spares that I need to get rid of to fund my own 66XL restoration.  PM me if interested in anything.
  • Parchment sunvisors (one mount broken)
  • Parchment kick panels - rough
  • Interior Trim:
    • Inside front Windshield
    • Inside Rear Window
    • Side glass upper trim (I'm missing one pc that I need to find)
  • Rear bumper - straight, but needs rechrome
  • Front bumper - slightly bent and needs rechrome
  • Front Suspension:
    • Upper & Lower control arm assy
    • Spindles
    • Drum Assembly
    • Front Springs
  • Power steering pump & steering linkages
  • Power steering cooler
  • Sway bar
  • R & L 1/4 glass (factory tinted)
  • R 1/4 glass (clear)
  • Parchment XL door panels, good cores
  • Black XL door panels w/trim, vinyl torn
  • DR Door w/glass & door handle
  • XL / 7Litre Hood
  • XL / 7Litre Trunk Lid
  • Dash Bezel (surrounds the heater controls/ignition)
  • Front & Rear outer bumper brackets
  • (2) Wiper Motors
  • Plastic column spacer & column bezel (where it attaches to dash)
  • Headlight Bezels (2LH & 1RH, nice no pits)
  • (3) sets of wiper arms
  • FOMOCO headlights
  • (2) clocks
  • XL dash inserts for AC car (woodgrain)
  • Black dash insert (Galaxie 500)
  • PRNDL selector for Cruise-o-matic column shift car
  • Day/Nite Mirror - Rough
  • Standard mirror - Nice
  • 1965 Galaxie Horn ring
  • (3) Taillight lenses (cracked)
  • (2) Back-up light assemblies
  • (2) Taillight buckets
  • (4) LTD wheel covers (black insert, needs replaced)
  • (2) Galaxie wheel covers (red insert, nice drivers)
  • (2) Dog dish hub caps for 14" rims
  • 4bbl carb spacer (maybe for SMOG cars?)
  • Pair C4AE-6090G Heads - Need rebuild
  • Heater plenum (includes heater core & blower wheel, but cracked on edge, have piece)
  • Dash Hood, ok shape, some curling at edges
  • Front & Rear window tracks
  • Wiper linkage
  • Fuel tank fill neck
  • Park brake cables
  • Glove box door
  • Hood hinges
  • XL pedal set w/trim rings
July 18, 2017 10:45 am  #2
Re: 1966 Galaxie Parts
